Motors
Crankshaft/Piston Binding Problem
<blockquote data-quote="macawman" data-source="post: 463500" data-attributes="member: 23375"><p>Sorry for the delay in getting back to this. March was a very rough month for me.</p><p>T</p><p>Turned out to be a totally different problem then I originally thought. The shaft of the connecting rods is offset from the center line of the rod to provide clearance to the counter weights mounted on the side of each crank journal. I had the Pistons installed in the wrong cylinders and the connecting rod shafts were binding against the counter weights.</p></blockquote><p></p>
[QUOTE="macawman, post: 463500, member: 23375"] Sorry for the delay in getting back to this. March was a very rough month for me. T Turned out to be a totally different problem then I originally thought. The shaft of the connecting rods is offset from the center line of the rod to provide clearance to the counter weights mounted on the side of each crank journal. I had the Pistons installed in the wrong cylinders and the connecting rod shafts were binding against the counter weights. [/QUOTE]
Motors
