Off The Water
Watering Hole
Crawfish trap?
<blockquote data-quote="crkdltr" data-source="post: 202302" data-attributes="member: 1225"><p>Not sure if this will be effective in your neck of the woods, but we use these here in the bayou.</p><p></p><p><img src="https://cdn.memphisnet.net/images/uploads/CrawfishNet130.gif" alt="" class="fr-fic fr-dii fr-draggable " style="" /></p><p></p><p>Set out a couple of dozen with fish head or some kind of bloody meat (beef melt (pancreas). Make sure to fashion a large safety pin out of coat hanger wire and secure the meat to the net otherwise it won't be there by the time you get back.</p><p></p><p>Trick to it is you need a 5 foot, or longer, stick with a small metal rod that you can slip into the loop and quickly lift it out of the water and dump it in a bucket.</p></blockquote><p></p>
[QUOTE="crkdltr, post: 202302, member: 1225"] Not sure if this will be effective in your neck of the woods, but we use these here in the bayou. [img]https://cdn.memphisnet.net/images/uploads/CrawfishNet130.gif[/img] Set out a couple of dozen with fish head or some kind of bloody meat (beef melt (pancreas). Make sure to fashion a large safety pin out of coat hanger wire and secure the meat to the net otherwise it won't be there by the time you get back. Trick to it is you need a 5 foot, or longer, stick with a small metal rod that you can slip into the loop and quickly lift it out of the water and dump it in a bucket. [/QUOTE]
Off The Water
Watering Hole
Crawfish trap?
