Boat House
drain plug ideas?
<blockquote data-quote="russ010" data-source="post: 131363" data-attributes="member: 677"><p>sorry I didn't see this sooner... I have used regular old clear caulk before. I basically did it just like you said - Put a bolt with washer on the outside, put the nut on, then filled the whole hole up with silicone... worked like a charm for about 5 years before I finally sold the boat. Last I heard, that is the same setup he's got on the boat. </p><p></p><p>Only reason it stayed permanent was because we flipped the boat over when we got it home.. it wasn't on a trailer, but in the back of a truck, so if it rained, we just flipped it over when we were done fishing.</p></blockquote><p></p>
[QUOTE="russ010, post: 131363, member: 677"] sorry I didn't see this sooner... I have used regular old clear caulk before. I basically did it just like you said - Put a bolt with washer on the outside, put the nut on, then filled the whole hole up with silicone... worked like a charm for about 5 years before I finally sold the boat. Last I heard, that is the same setup he's got on the boat. Only reason it stayed permanent was because we flipped the boat over when we got it home.. it wasn't on a trailer, but in the back of a truck, so if it rained, we just flipped it over when we were done fishing. [/QUOTE]
Boat House
drain plug ideas?
