Motors
EVINRUDE 9.9HP MIND OF ITS OWN! HALF RUNNING AND NO WATER
<blockquote data-quote="lukelona" data-source="post: 223178" data-attributes="member: 6869"><p>ok sounds like you know your boat motors!</p><p>i am sorry about my questions just tryin to learn.</p><p>i am gonna replace waterpump and housing</p><p>also may replace thermostat and fuel pump if you think that </p><p>should be done also.</p><p>total should be around $55-80 for all.</p><p>i know a rebuild kit is much cheaper then whole fuel pump.</p><p>i figure $55 if i get a rebuild or $80 for whole pump and other parts</p><p></p><p>(i also still need rewind starter asembeled but im not sure the best way </p><p>to install the rewind spring. also when i look at diagram for recoil it shows</p><p>a retainer for the spring? it seems like the new spring just goes right on the rewind starter houseing. need help on that too)</p><p></p><p>is this the proper approach at this point?</p></blockquote><p></p>
[QUOTE="lukelona, post: 223178, member: 6869"] ok sounds like you know your boat motors! i am sorry about my questions just tryin to learn. i am gonna replace waterpump and housing also may replace thermostat and fuel pump if you think that should be done also. total should be around $55-80 for all. i know a rebuild kit is much cheaper then whole fuel pump. i figure $55 if i get a rebuild or $80 for whole pump and other parts (i also still need rewind starter asembeled but im not sure the best way to install the rewind spring. also when i look at diagram for recoil it shows a retainer for the spring? it seems like the new spring just goes right on the rewind starter houseing. need help on that too) is this the proper approach at this point? [/QUOTE]
Motors
