Motors
evinrude help onstarcraft
<blockquote data-quote="MDCrappie" data-source="post: 311660" data-attributes="member: 160"><p>Is your prop 1 piece? Being that it is a drive pin prop it could still have a rubber hub. If it's 2 piece I would put a mark on the blade portion of the hub in line with the slot for your pin. Run it and see if the mark still lines up. </p><p></p><p></p><p></p><p>I think you will be hearing all kinds of noise and the motor will be hard to shift, or popping out of gear if dog goes bad. A clutch dog is not like a clutch in a car in that it can "slip"? to get you going.</p></blockquote><p></p>
[QUOTE="MDCrappie, post: 311660, member: 160"] Is your prop 1 piece? Being that it is a drive pin prop it could still have a rubber hub. If it's 2 piece I would put a mark on the blade portion of the hub in line with the slot for your pin. Run it and see if the mark still lines up. I think you will be hearing all kinds of noise and the motor will be hard to shift, or popping out of gear if dog goes bad. A clutch dog is not like a clutch in a car in that it can "slip"? to get you going. [/QUOTE]
Motors
