Boat House
Factory floor question/MYSTERY
<blockquote data-quote="screwballl" data-source="post: 182821" data-attributes="member: 4837"><p>Maybe that is part of the problem, try putting it in a shallow pond and let it sit for a little while to see if it takes on any water. It is not much of a problem if the water drains from top to the underside of the flooring, which is likely just some foam to keep it buoyant but also designed to stay afloat even when soaked with water. </p><p></p><p>The problem will come in if there are leaks from the underside while it is on the water.</p></blockquote><p></p>
[QUOTE="screwballl, post: 182821, member: 4837"] Maybe that is part of the problem, try putting it in a shallow pond and let it sit for a little while to see if it takes on any water. It is not much of a problem if the water drains from top to the underside of the flooring, which is likely just some foam to keep it buoyant but also designed to stay afloat even when soaked with water. The problem will come in if there are leaks from the underside while it is on the water. [/QUOTE]
Boat House
