Boat House
First post with some general questions
<blockquote data-quote="DaleH" data-source="post: 384215" data-attributes="member: 15636"><p>FWIW I put my stern cleats on a 45-degree angle, using 4-5" nylon (plastic) or marelon cleats using SS #10 hardware insulated from the aluminum corner piece by adhesive-lined heatshrink on the bolt body and nylon washers under that pieve for the nylok nuts to bear against. No corrosion that way due to dis-similar metals, especially if/when used in a saltwater environment.</p></blockquote><p></p>
[QUOTE="DaleH, post: 384215, member: 15636"] FWIW I put my stern cleats on a 45-degree angle, using 4-5" nylon (plastic) or marelon cleats using SS #10 hardware insulated from the aluminum corner piece by adhesive-lined heatshrink on the bolt body and nylon washers under that pieve for the nylok nuts to bear against. No corrosion that way due to dis-similar metals, especially if/when used in a saltwater environment. [/QUOTE]
Boat House
