Boat House
Fixing holes on top of boat
<blockquote data-quote="richg99" data-source="post: 384408" data-attributes="member: 4376"><p>When faced with that same issue in the past....I've mounted the trolling motor onto a separate board, then mounted the board onto the boat, using the existing holes. On the board, I use stainless steel T nuts from the bottom of the new mounting board.</p><p></p><p>That process gives you a lot more flexibility anytime you are putting a different trolling motor onto an existing mount area and holes.</p></blockquote><p></p>
[QUOTE="richg99, post: 384408, member: 4376"] When faced with that same issue in the past....I've mounted the trolling motor onto a separate board, then mounted the board onto the boat, using the existing holes. On the board, I use stainless steel T nuts from the bottom of the new mounting board. That process gives you a lot more flexibility anytime you are putting a different trolling motor onto an existing mount area and holes. [/QUOTE]
Boat House
