Motors
flywheel questions
<blockquote data-quote="ultra353" data-source="post: 307250" data-attributes="member: 2751"><p>Get a good flywheel puller with some Grade 8 bolts. The tool is named " flywheel Puller" for a reason, Its designed to do just that, pull the flywheel off the crankshaft. It will probably make a loud bang when it comes loose, don`t be alarmed and think you broke something. When reinstalling the flywheel make sure you use a Torque Wrench and tighten to the factory specs or you`ll have problems.</p></blockquote><p></p>
[QUOTE="ultra353, post: 307250, member: 2751"] Get a good flywheel puller with some Grade 8 bolts. The tool is named " flywheel Puller" for a reason, Its designed to do just that, pull the flywheel off the crankshaft. It will probably make a loud bang when it comes loose, don`t be alarmed and think you broke something. When reinstalling the flywheel make sure you use a Torque Wrench and tighten to the factory specs or you`ll have problems. [/QUOTE]
Motors
flywheel questions
