Motors
Flywheel stuck
<blockquote data-quote="ultra353" data-source="post: 300756" data-attributes="member: 2751"><p>Are you using a Torque wrench when you tighten down the factory nut to the correct specs, if not it will continue to come loose. Make sure you check the crankshaft key way for any damage from the flywheel coming off, use a factory OMC key and not some hardware store woodruff key. Good luck, those are great motors! P.S, If Torqued properly using the correct parts you won`t need ( or want ) any loctite on there.</p></blockquote><p></p>
[QUOTE="ultra353, post: 300756, member: 2751"] Are you using a Torque wrench when you tighten down the factory nut to the correct specs, if not it will continue to come loose. Make sure you check the crankshaft key way for any damage from the flywheel coming off, use a factory OMC key and not some hardware store woodruff key. Good luck, those are great motors! P.S, If Torqued properly using the correct parts you won`t need ( or want ) any loctite on there. [/QUOTE]
Motors
Flywheel stuck
