Boat House
Foam & Deck clearance?
<blockquote data-quote="CedarRiverScooter" data-source="post: 430253" data-attributes="member: 15465"><p>I'd seal the underside of the plywood & after full cure glue the foam to it. Put a full bead around the circumference to eliminate water sucking in.</p></blockquote><p></p>
[QUOTE="CedarRiverScooter, post: 430253, member: 15465"] I'd seal the underside of the plywood & after full cure glue the foam to it. Put a full bead around the circumference to eliminate water sucking in. [/QUOTE]
Boat House
