Boat House
Free Evinrude 4.5HP
<blockquote data-quote="bassboy1" data-source="post: 178858" data-attributes="member: 55"><p>You did good there. That motor is the same as the later Johnson/Evinrude 4 Deluxe (pre '85 was 4.5, then when the ratings changed, the motor was changed to the 4 Deluxe). Either the best or second best motor in existence, all makes, models and sizes included, so far as I'm concerned (and I'm not alone in that assumption). </p><p>You've got a 4 horse (post '85, rating, so a current rated 4 horse) motor, with a F-N-R shifter, large diameter flywheel (makes it the smoothest idling motor I've ever had), and still under 50 pounds. </p><p></p><p>Not a bad find at all.</p></blockquote><p></p>
[QUOTE="bassboy1, post: 178858, member: 55"] You did good there. That motor is the same as the later Johnson/Evinrude 4 Deluxe (pre '85 was 4.5, then when the ratings changed, the motor was changed to the 4 Deluxe). Either the best or second best motor in existence, all makes, models and sizes included, so far as I'm concerned (and I'm not alone in that assumption). You've got a 4 horse (post '85, rating, so a current rated 4 horse) motor, with a F-N-R shifter, large diameter flywheel (makes it the smoothest idling motor I've ever had), and still under 50 pounds. Not a bad find at all. [/QUOTE]
Boat House
Free Evinrude 4.5HP
