Motors
Frozen steering tube
<blockquote data-quote="doodlebug" data-source="post: 411516" data-attributes="member: 20465"><p>I've done everything mentioned except applying heat. The cable itself is a pile of rust too. No need to try and save it. I just cut it off to get it out of the way as I don't need it anyway. The part inside of the steering tube/tilt tube is frozen rock solid with rust. I've sprayed it good with PB Blaster and have tried knocking it loose with a big hammer, but no success. I think I'll get the torch on it and see if that helps any. I've never seen anything so frozen like this. Thanks for all the tips. If you can think of anything else, please let me know. Thanks</p></blockquote><p></p>
[QUOTE="doodlebug, post: 411516, member: 20465"] I've done everything mentioned except applying heat. The cable itself is a pile of rust too. No need to try and save it. I just cut it off to get it out of the way as I don't need it anyway. The part inside of the steering tube/tilt tube is frozen rock solid with rust. I've sprayed it good with PB Blaster and have tried knocking it loose with a big hammer, but no success. I think I'll get the torch on it and see if that helps any. I've never seen anything so frozen like this. Thanks for all the tips. If you can think of anything else, please let me know. Thanks [/QUOTE]
Motors
