Boat House
Gas tank preference.
<blockquote data-quote="RedHatRedNeck" data-source="post: 438100" data-attributes="member: 22224"><p>Boat I have is 04. Motor is 02. PO always drained tank during winter. I will probably do same and just add small amounts if running during winter unless hunting multiple days in a row. Original 12 gal red plastic tank is under aluminum back deck. No vents are set up on top, but air can flow through fore to aft underneath back deck. Back deck stops about 12" from transom. I'm running 5oz of stabil for every 12 gal of gas. No issues with tank at all. When I move 2 of the 3 batteries from that back compartment to the front of the boat I may have room to either install a larger plastic tank or a metal tank of some sorts. Not sure what I'll be doing yet.</p></blockquote><p></p>
[QUOTE="RedHatRedNeck, post: 438100, member: 22224"] Boat I have is 04. Motor is 02. PO always drained tank during winter. I will probably do same and just add small amounts if running during winter unless hunting multiple days in a row. Original 12 gal red plastic tank is under aluminum back deck. No vents are set up on top, but air can flow through fore to aft underneath back deck. Back deck stops about 12" from transom. I'm running 5oz of stabil for every 12 gal of gas. No issues with tank at all. When I move 2 of the 3 batteries from that back compartment to the front of the boat I may have room to either install a larger plastic tank or a metal tank of some sorts. Not sure what I'll be doing yet. [/QUOTE]
Boat House
