Motors
Gear Problems
<blockquote data-quote="SumDumGuy" data-source="post: 333482" data-attributes="member: 12459"><p>If all you did was drop the lower to change impeller then ensure that your bottom shift rod is fully seated in the shift rod link. Sometimes it will appear to be fit, but is trapped lower than it should be.</p><p>Easily checked by removing the small access cover plate.</p><p></p><p><img src="https://s20.postimg.org/bbwo4b6jh/piv.png" alt="" class="fr-fic fr-dii fr-draggable " style="" /></p></blockquote><p></p>
[QUOTE="SumDumGuy, post: 333482, member: 12459"] If all you did was drop the lower to change impeller then ensure that your bottom shift rod is fully seated in the shift rod link. Sometimes it will appear to be fit, but is trapped lower than it should be. Easily checked by removing the small access cover plate. [img]https://s20.postimg.org/bbwo4b6jh/piv.png[/img] [/QUOTE]
Motors
Gear Problems
