Boat House
Gluvit and fiberglass over coats
<blockquote data-quote="ben2go" data-source="post: 93854" data-attributes="member: 751"><p>Yes,the heat and chemicals in the epoxy could soften up the Gluvit and make a really big mess.I haven't looked at the MSDS for Gluvit or the epoxy you plan to use,but certain type of chemicals in those coatings can react and possibly cause a flash fire.I would be very hesitant to lay epoxy over Gluvit.If you are looking to mold over it,you could use peel ply to protect the Gluvit coated surfaces.The peel ply will not stick to epoxy or Gluvit and should peel off like paper on the back of a decal.</p></blockquote><p></p>
[QUOTE="ben2go, post: 93854, member: 751"] Yes,the heat and chemicals in the epoxy could soften up the Gluvit and make a really big mess.I haven't looked at the MSDS for Gluvit or the epoxy you plan to use,but certain type of chemicals in those coatings can react and possibly cause a flash fire.I would be very hesitant to lay epoxy over Gluvit.If you are looking to mold over it,you could use peel ply to protect the Gluvit coated surfaces.The peel ply will not stick to epoxy or Gluvit and should peel off like paper on the back of a decal. [/QUOTE]
Boat House
