Off The Water
Watering Hole
Got the boat started!
<blockquote data-quote="wasilvers" data-source="post: 194792" data-attributes="member: 1776"><p>I've heard that before, but have to say, it is appropriate in the right situation. </p><p></p><p>Never use it on a 'dry' engine, it should not be part of the routine to get it started. But if I have cranked on it for a bit, pulled the plugs and they are 'damp'. And the motor is just soooo close to kicking over, yeah, it can be used. After all, the oil in the gas will still lube till more gets in there.</p><p></p><p>When my motor feels like it's about to fire, the starter kicks off. So when it is close to start (like when I didn't give it any throttle) will go crank, pop, whirrlllll (as the starter spins out).</p></blockquote><p></p>
[QUOTE="wasilvers, post: 194792, member: 1776"] I've heard that before, but have to say, it is appropriate in the right situation. Never use it on a 'dry' engine, it should not be part of the routine to get it started. But if I have cranked on it for a bit, pulled the plugs and they are 'damp'. And the motor is just soooo close to kicking over, yeah, it can be used. After all, the oil in the gas will still lube till more gets in there. When my motor feels like it's about to fire, the starter kicks off. So when it is close to start (like when I didn't give it any throttle) will go crank, pop, whirrlllll (as the starter spins out). [/QUOTE]
Off The Water
Watering Hole
