Motors
Having problems with motor
<blockquote data-quote="flintcreek" data-source="post: 140514" data-attributes="member: 1463"><p>I do agree first try the prop and hope it works, if not then first off drain the oil out of the lower unit you plan to use, check it for metal and if everything looks good then all I would do is drop the lower unit and make sure both lower units have the same shafts and shift linkage, if so put in the new water pump impeller and put it back together. Doing 2 at one time it will probably take a couple of hours. But for the money I would buy the extra motor anyway....Flintcreek</p></blockquote><p></p>
[QUOTE="flintcreek, post: 140514, member: 1463"] I do agree first try the prop and hope it works, if not then first off drain the oil out of the lower unit you plan to use, check it for metal and if everything looks good then all I would do is drop the lower unit and make sure both lower units have the same shafts and shift linkage, if so put in the new water pump impeller and put it back together. Doing 2 at one time it will probably take a couple of hours. But for the money I would buy the extra motor anyway....Flintcreek [/QUOTE]
Motors
