Boat House
Help identifying 1987 Duracraft
<blockquote data-quote="Buckethead" data-source="post: 424993" data-attributes="member: 9470"><p>My duracraft is a 1974 model 1720. It measures 16' 6" long with a 48" bottom. The gunwales are 20" high. What I've found is they assigned model numbers from the length and gunwale height. My grandpa had a 16' that was 15' 6" long with a 42" bottom and 20" gunwales that was called a model 1620. I would assume that in 1987 model numbers were assigned the same way. Depending on the gunwale height it could be a 1620 or 1622 since you have the added width. Just a guess.</p></blockquote><p></p>
[QUOTE="Buckethead, post: 424993, member: 9470"] My duracraft is a 1974 model 1720. It measures 16' 6" long with a 48" bottom. The gunwales are 20" high. What I've found is they assigned model numbers from the length and gunwale height. My grandpa had a 16' that was 15' 6" long with a 42" bottom and 20" gunwales that was called a model 1620. I would assume that in 1987 model numbers were assigned the same way. Depending on the gunwale height it could be a 1620 or 1622 since you have the added width. Just a guess. [/QUOTE]
Boat House
