Boat House
help with deck
<blockquote data-quote="crkdltr" data-source="post: 190262" data-attributes="member: 1225"><p>You are correct, you would cut two pieces of plywood for your deck if it's longer than 48". I know your exactly confusion but it dawned on me after thinking about it for a little while. I'm sure they make larger sheets of plywood but at a premium. </p><p></p><p>If you're worried about the strength or integrity of the butt joint, you could dado the two pieces of plywood and make a lap joint. </p><p></p><p>Good luck.</p></blockquote><p></p>
[QUOTE="crkdltr, post: 190262, member: 1225"] You are correct, you would cut two pieces of plywood for your deck if it's longer than 48". I know your exactly confusion but it dawned on me after thinking about it for a little while. I'm sure they make larger sheets of plywood but at a premium. If you're worried about the strength or integrity of the butt joint, you could dado the two pieces of plywood and make a lap joint. Good luck. [/QUOTE]
Boat House
help with deck
