Electrical
Help with jon boat wiring
<blockquote data-quote="Target" data-source="post: 430315" data-attributes="member: 21887"><p>I am in the middle of adding several electronics to my jon boat. I included a diagram of what I have so far. </p><p></p><p>I would like the nav lights and LEDs (# 6, 7, 8) on a switch. Thinking one of these:<a href="https://www.amazon.com/Iztoss-Marine-Electric-Toggle-Switch/dp/B019XWD0IE" target="_blank">https://www.amazon.com/Iztoss-Marine-Electric-Toggle-Switch/dp/B019XWD0IE</a></p><p></p><p>I have never done switches before and get confused with bus bars, and fuse bars, etc. Can anyone recommend a simple way to wire this up? I definitely want a switch for the lights and want to avoid having tons of wires run to the battery. </p><p>Am I correct that a bus bar is basically a joining spot for all the wires so that you don't have them all running to the battery?</p><p></p><p>Thanks in advance.</p></blockquote><p></p>
[QUOTE="Target, post: 430315, member: 21887"] I am in the middle of adding several electronics to my jon boat. I included a diagram of what I have so far. I would like the nav lights and LEDs (# 6, 7, 8) on a switch. Thinking one of these:[url]https://www.amazon.com/Iztoss-Marine-Electric-Toggle-Switch/dp/B019XWD0IE[/url] I have never done switches before and get confused with bus bars, and fuse bars, etc. Can anyone recommend a simple way to wire this up? I definitely want a switch for the lights and want to avoid having tons of wires run to the battery. Am I correct that a bus bar is basically a joining spot for all the wires so that you don't have them all running to the battery? Thanks in advance. [/QUOTE]
Electrical
