Boat House
Help with replacing vinyl
<blockquote data-quote="Jetech" data-source="post: 443538" data-attributes="member: 22271"><p>You could also use aircraft "pull" type rivets. They are structural rivets <a href="https://www.aircraftspruce.com/catalog/hapages/cherrymax.php" target="_blank">https://www.aircraftspruce.com/catalog/hapages/cherrymax.php</a> Keep in mind they use a 100* countersink.</p><p>You may try smoothing the area around the rivet head with something like aluminum tape <a href="https://www.aircraftspruce.com/catalog/cspages/3mproptape.php?clickkey=23141" target="_blank">https://www.aircraftspruce.com/catalog/cspages/3mproptape.php?clickkey=23141</a>. Place the tape around the rivet head but not over it, building the area up around it. You could layer the tape making a taper to try and eliminate any bumps. Other types of tape may work also.</p></blockquote><p></p>
[QUOTE="Jetech, post: 443538, member: 22271"] You could also use aircraft "pull" type rivets. They are structural rivets [url]https://www.aircraftspruce.com/catalog/hapages/cherrymax.php[/url] Keep in mind they use a 100* countersink. You may try smoothing the area around the rivet head with something like aluminum tape [url]https://www.aircraftspruce.com/catalog/cspages/3mproptape.php?clickkey=23141[/url]. Place the tape around the rivet head but not over it, building the area up around it. You could layer the tape making a taper to try and eliminate any bumps. Other types of tape may work also. [/QUOTE]
Boat House
