Motors
Help!!!! Yamaha F25/704 problem
<blockquote data-quote="turbotodd" data-source="post: 347595" data-attributes="member: 7376"><p>I'm guessing the guys at hull truth told you how the prime starter works. Its not a choke. Advancing the throttle on a cold engine makes it harder to start. Idle only. If the prime starter works like it should, and the passages are clear, it should fire off within a revolution or two without any throttle.</p><p></p><p>I like the 703 better than the 704 for a standard remote but either one works just fine. Good luck to ya!</p></blockquote><p></p>
[QUOTE="turbotodd, post: 347595, member: 7376"] I'm guessing the guys at hull truth told you how the prime starter works. Its not a choke. Advancing the throttle on a cold engine makes it harder to start. Idle only. If the prime starter works like it should, and the passages are clear, it should fire off within a revolution or two without any throttle. I like the 703 better than the 704 for a standard remote but either one works just fine. Good luck to ya! [/QUOTE]
Motors
