Boat House
Holes to fix
<blockquote data-quote="DearJon" data-source="post: 312921" data-attributes="member: 9078"><p>The JB Weld should hold, but if it starts to leak again then you should get it permanently welded. One thing to keep in mind is that it would be easy to weld now because the boat is relatively empty in it's current state. If you do a full build on the boat, and then it starts to leak in the future, you may have problems getting a welder into those problem areas. Once you start adding casting decks and storage bins/hatches, things can get a little crowded. Just something to consider. Good luck.</p></blockquote><p></p>
[QUOTE="DearJon, post: 312921, member: 9078"] The JB Weld should hold, but if it starts to leak again then you should get it permanently welded. One thing to keep in mind is that it would be easy to weld now because the boat is relatively empty in it's current state. If you do a full build on the boat, and then it starts to leak in the future, you may have problems getting a welder into those problem areas. Once you start adding casting decks and storage bins/hatches, things can get a little crowded. Just something to consider. Good luck. [/QUOTE]
Boat House
Holes to fix
