Boat House
How do I modify front walking deck on a 16' Lowe
<blockquote data-quote="Ouachita" data-source="post: 74020" data-attributes="member: 186"><p>The brackets most use are Simpson Strong Tie brackets used for wood framing. They are galvanized and shouldn't be in direct contact with aluminum. If you are using them to connect directly to your boat you need to isolate them from the metal with nylon washers or some type of gasket material.</p></blockquote><p></p>
[QUOTE="Ouachita, post: 74020, member: 186"] The brackets most use are Simpson Strong Tie brackets used for wood framing. They are galvanized and shouldn't be in direct contact with aluminum. If you are using them to connect directly to your boat you need to isolate them from the metal with nylon washers or some type of gasket material. [/QUOTE]
Boat House
