Boat House
How do I replace this Transom?
<blockquote data-quote="cybereyes" data-source="post: 74545" data-attributes="member: 1168"><p>Thanks guys. I've started to paint my boat this weekend, and got all the stuff out of the inside. Looks like I'm going to have to rewire everything too. Whoever had it before was basically just wrapping loose wires around a battery terminal, and making wires longer by twisting two wires together and smothering it in black tape. which is not my style. So Im doing it all over from scratch before I start putting the deck in. </p><p></p><p>As far as the transom I will probably try and get some of those bolts and rivets out this evening to see what I'm going to be dealing with. The first picture which shows that little metal plate is covering a long board which looks to be pretty thick. It looks almost like about as wide as a 2x5. Then it has that little section of plywood on the other side which you see in the 2nd picture. This should be fun.</p></blockquote><p></p>
[QUOTE="cybereyes, post: 74545, member: 1168"] Thanks guys. I've started to paint my boat this weekend, and got all the stuff out of the inside. Looks like I'm going to have to rewire everything too. Whoever had it before was basically just wrapping loose wires around a battery terminal, and making wires longer by twisting two wires together and smothering it in black tape. which is not my style. So Im doing it all over from scratch before I start putting the deck in. As far as the transom I will probably try and get some of those bolts and rivets out this evening to see what I'm going to be dealing with. The first picture which shows that little metal plate is covering a long board which looks to be pretty thick. It looks almost like about as wide as a 2x5. Then it has that little section of plywood on the other side which you see in the 2nd picture. This should be fun. [/QUOTE]
Boat House
