Boat House
How do you plug a through-hull fitting?
<blockquote data-quote="byteman" data-source="post: 276099" data-attributes="member: 2712"><p>I did something similar on my re-build. What I did was cut some pieces of aluminum bigger than the hole to use as a backer. A little 5200 to seal the backer and some rivets to hold the backer plate in place while it is all curing. That's it the hole is sealed. If you want the patch to disappear altogether then fill in the depression with some Marine-Tex</p></blockquote><p></p>
[QUOTE="byteman, post: 276099, member: 2712"] I did something similar on my re-build. What I did was cut some pieces of aluminum bigger than the hole to use as a backer. A little 5200 to seal the backer and some rivets to hold the backer plate in place while it is all curing. That's it the hole is sealed. If you want the patch to disappear altogether then fill in the depression with some Marine-Tex [/QUOTE]
Boat House
