Boat House
Hydro turf install question
<blockquote data-quote="highgeardaddy" data-source="post: 285741" data-attributes="member: 10000"><p>Well I'm done with the turf install on the Tracker- for future reference if you use Weldwood Contact cement on aluminum you dont need anything to hold it down over irregular surfaces. or press it down to cure If you let it "flash-cure" ~15 minutes afer applying to each surface (turf and boat deck) in accordance with the directions once you touch it down, you cant move it. The biggest challenge is getting that first "stick" of each cut panel straight. Suggest gGet a buddy or two to help keep things in order if you are placing big hydro-turf panels, again once it touches the Weldwood-its there to stay. Lookout ducks, we're almost done with this renovation.</p><p></p><p>Cheers.</p></blockquote><p></p>
[QUOTE="highgeardaddy, post: 285741, member: 10000"] Well I'm done with the turf install on the Tracker- for future reference if you use Weldwood Contact cement on aluminum you dont need anything to hold it down over irregular surfaces. or press it down to cure If you let it "flash-cure" ~15 minutes afer applying to each surface (turf and boat deck) in accordance with the directions once you touch it down, you cant move it. The biggest challenge is getting that first "stick" of each cut panel straight. Suggest gGet a buddy or two to help keep things in order if you are placing big hydro-turf panels, again once it touches the Weldwood-its there to stay. Lookout ducks, we're almost done with this renovation. Cheers. [/QUOTE]
Boat House
