Boat House
Introductiion - New Member
<blockquote data-quote="richg99" data-source="post: 433281" data-attributes="member: 4376"><p>Welcome aboard. Always fun to have another inmate join the asylum.</p><p></p><p>Sounds like your new yacht hasn't been run in a while, other than your test. You might consider changing out the water pump impeller. They get stiff when set up for a long time and have been known to break and throw small pieces into the cooling system.</p><p></p><p>Just as the rubber in the tires can be dried out from sitting up, the impeller can, too.</p><p></p><p>You probably know, if you change out the bunks, to NOT USE Treated lumber. Sounded like you will be simply changing out the carpet, though.</p><p></p><p>We look forward to reports of your efforts.</p><p></p><p>regards, richg99</p><p></p><p>p.s. Helps some if you add your general location in your profile. You might find a helping hand right nearby.</p></blockquote><p></p>
[QUOTE="richg99, post: 433281, member: 4376"] Welcome aboard. Always fun to have another inmate join the asylum. Sounds like your new yacht hasn't been run in a while, other than your test. You might consider changing out the water pump impeller. They get stiff when set up for a long time and have been known to break and throw small pieces into the cooling system. Just as the rubber in the tires can be dried out from sitting up, the impeller can, too. You probably know, if you change out the bunks, to NOT USE Treated lumber. Sounded like you will be simply changing out the carpet, though. We look forward to reports of your efforts. regards, richg99 p.s. Helps some if you add your general location in your profile. You might find a helping hand right nearby. [/QUOTE]
Boat House
