Boat House
Is my Transom Repair OK ??
<blockquote data-quote="Ringo Steele" data-source="post: 233360" data-attributes="member: 6694"><p>Thanks Sixgun! I did find out from West Systems about their epoxy that I will need a top coat of some type...</p><p>"Our WEST SYSTEM® 207 Special Clear Hardener has a small amount of UV inhibitor added – but not enough to be a final finish. The UV inhibitor depresses the physical properties and our products are first and foremost structural adhesives, so we do not make just a final coating. We always recommend using an over coating – a clear urethane, varnish, or paint. Here is a link about Finish Coatings, </p><p>https://www.westsystem.com/ss/finish-coatings/"</p><p></p><p>I'll <em>probably</em> go with Spar Urethane for that.</p></blockquote><p></p>
[QUOTE="Ringo Steele, post: 233360, member: 6694"] Thanks Sixgun! I did find out from West Systems about their epoxy that I will need a top coat of some type... "Our WEST SYSTEM® 207 Special Clear Hardener has a small amount of UV inhibitor added – but not enough to be a final finish. The UV inhibitor depresses the physical properties and our products are first and foremost structural adhesives, so we do not make just a final coating. We always recommend using an over coating – a clear urethane, varnish, or paint. Here is a link about Finish Coatings, https://www.westsystem.com/ss/finish-coatings/" I'll [i]probably[/i] go with Spar Urethane for that. [/QUOTE]
Boat House
