Motors
jet outboard info needed.
<blockquote data-quote="Scottinva" data-source="post: 338017" data-attributes="member: 4987"><p>Depending on how your jack plate is setup, you could raise the motor up 5" and it would work. Otherwise, you would need to raise your transom 5". Speed will probably be in the 25-27 mph range with a 60/40. With a light riveted boat, you will be able to run in 6" easily if the boat is setup right and runs level. I wouldn't worry about a tunnel if I were you. You would have probably got more response if you would have posted in the jet boat section.</p><p></p><p>Scott</p></blockquote><p></p>
[QUOTE="Scottinva, post: 338017, member: 4987"] Depending on how your jack plate is setup, you could raise the motor up 5" and it would work. Otherwise, you would need to raise your transom 5". Speed will probably be in the 25-27 mph range with a 60/40. With a light riveted boat, you will be able to run in 6" easily if the boat is setup right and runs level. I wouldn't worry about a tunnel if I were you. You would have probably got more response if you would have posted in the jet boat section. Scott [/QUOTE]
Motors
