Boat House
Johnson 15 top speed
<blockquote data-quote="wmk0002" data-source="post: 434021" data-attributes="member: 13975"><p>That's better and good enough to not be worth doing much fiddling with the motor, but I would check to see that the carb butterfly is opening fully to the horizontal position. If it is opening fully maybe check the compression and try doing a decarb. And as always check the condition of the spark plugs and their gap.</p></blockquote><p></p>
[QUOTE="wmk0002, post: 434021, member: 13975"] That's better and good enough to not be worth doing much fiddling with the motor, but I would check to see that the carb butterfly is opening fully to the horizontal position. If it is opening fully maybe check the compression and try doing a decarb. And as always check the condition of the spark plugs and their gap. [/QUOTE]
Boat House
