Motors
Johnson 70 surging at wot
<blockquote data-quote="Mack17" data-source="post: 328903" data-attributes="member: 12565"><p>Appreciate the help guys.Yea the tank was pretty much full when it started surging. I thought I fixed it when I replaced the line,filter and quick connects.And the last time I had it out it ran fine all day so who knows.I'm going to replace the fuel pump and go thru each carb and check all fuel lines and for vaccuum leaks.It may be sucking air somewhere.Boat is out of commission for right now as I am recarpeting the deck and going to repaint the hull,motor and trailer.Also have to fix the power tilt/trim and swivel bracket so I have plenty of time to go thru everything properly.</p></blockquote><p></p>
[QUOTE="Mack17, post: 328903, member: 12565"] Appreciate the help guys.Yea the tank was pretty much full when it started surging. I thought I fixed it when I replaced the line,filter and quick connects.And the last time I had it out it ran fine all day so who knows.I'm going to replace the fuel pump and go thru each carb and check all fuel lines and for vaccuum leaks.It may be sucking air somewhere.Boat is out of commission for right now as I am recarpeting the deck and going to repaint the hull,motor and trailer.Also have to fix the power tilt/trim and swivel bracket so I have plenty of time to go thru everything properly. [/QUOTE]
Motors
