Motors
johnson and evinrude 9.5 hp recoil
<blockquote data-quote="DaleH" data-source="post: 388986" data-attributes="member: 15636"><p><em>"To replace the starter rope, remove the rope, turn the spool 18 turns counterclockwise using a large flat screwdriver. Use the handles of a pair of pliers or screwdriver or similar tool to wedge the pinion teeth into the flywheel teeth, so it can not retract. Reinsert the rope and tie a knot. Allow the spool to rewind the rope. </em></p><p><em></em></p><p><em>If everything is already assembled and you need to adjust the tension, no need to make it too complicated. Pull the rope out so you have 2-3 free rounds/grooves for the rope on the spindle. Jam the spool as mentioned above. Take the rope out of the handle and 'thread' it around the free grooves in the spindle, then out back to the handle again. Test for retract ability."</em></p></blockquote><p></p>
[QUOTE="DaleH, post: 388986, member: 15636"] [i]"To replace the starter rope, remove the rope, turn the spool 18 turns counterclockwise using a large flat screwdriver. Use the handles of a pair of pliers or screwdriver or similar tool to wedge the pinion teeth into the flywheel teeth, so it can not retract. Reinsert the rope and tie a knot. Allow the spool to rewind the rope. If everything is already assembled and you need to adjust the tension, no need to make it too complicated. Pull the rope out so you have 2-3 free rounds/grooves for the rope on the spindle. Jam the spool as mentioned above. Take the rope out of the handle and 'thread' it around the free grooves in the spindle, then out back to the handle again. Test for retract ability."[/i] [/QUOTE]
Motors
