Boat House
Jon Boat Floor
<blockquote data-quote="Mainline9" data-source="post: 442757" data-attributes="member: 22243"><p>Advantech is NOT plywood but rather oriented strandboard. 7/16” OSB is heavier (15-20%) than 1/2” plywood and although it is made with exterior resins it will not withstand repeated soakings - it is intended to be used where moderate exposure to the elements exist, as in framing a house. Do yourself a favor and use a sanded panel, like BCX. Yes, it will cost you more initially, but the weight savings, durability (paint & edge seal) and improved fastener holding properties will be worth it.</p><p></p><p></p><p>Sent from my iPad using Tapatalk</p></blockquote><p></p>
[QUOTE="Mainline9, post: 442757, member: 22243"] Advantech is NOT plywood but rather oriented strandboard. 7/16” OSB is heavier (15-20%) than 1/2” plywood and although it is made with exterior resins it will not withstand repeated soakings - it is intended to be used where moderate exposure to the elements exist, as in framing a house. Do yourself a favor and use a sanded panel, like BCX. Yes, it will cost you more initially, but the weight savings, durability (paint & edge seal) and improved fastener holding properties will be worth it. Sent from my iPad using Tapatalk [/QUOTE]
Boat House
Jon Boat Floor
