Boat House
Just bought my first Jon Boat.
<blockquote data-quote="Ringo Steele" data-source="post: 244706" data-attributes="member: 6694"><p>Seal with epoxy or SPAR urethane after you get it cut out and all the holes drilled (slightly oversize) and allow the sealant of choice to coat the interiors of the holes too. Here's mine, epoxy coated... I used exterior grade 3/4" plywood, 2 layers glued with Titebond III waterproof glue:</p></blockquote><p></p>
[QUOTE="Ringo Steele, post: 244706, member: 6694"] Seal with epoxy or SPAR urethane after you get it cut out and all the holes drilled (slightly oversize) and allow the sealant of choice to coat the interiors of the holes too. Here's mine, epoxy coated... I used exterior grade 3/4" plywood, 2 layers glued with Titebond III waterproof glue: [/QUOTE]
Boat House
