Boat House
LED Lighting.
<blockquote data-quote="huntinfool" data-source="post: 354120" data-attributes="member: 1931"><p>DrNip's drawing is correct. However you only need an on off switch. You can run as many lights off one switch as needed. </p><p>Do you have any other type of fuses on your boat? If so I'd go to the local auto parts store and get a fuse holder that is the same as the other fuses ( that way you only have one type of fuse to buy) and install it.</p><p></p><p>The ground on a battery is the - negative terminal.</p><p>The + positive is the power side.</p></blockquote><p></p>
[QUOTE="huntinfool, post: 354120, member: 1931"] DrNip's drawing is correct. However you only need an on off switch. You can run as many lights off one switch as needed. Do you have any other type of fuses on your boat? If so I'd go to the local auto parts store and get a fuse holder that is the same as the other fuses ( that way you only have one type of fuse to buy) and install it. The ground on a battery is the - negative terminal. The + positive is the power side. [/QUOTE]
Boat House
LED Lighting.
