Boat House
looking for brackets
<blockquote data-quote="Earlo" data-source="post: 177321" data-attributes="member: 4386"><p>I second what Josh says. For anything contacting the boat, you can make some brackets out of aluminum angle. Also, be sure and use wood that is NOT pressure treated. The copper in treated wood will contribute to corrosion also. I used galvanized strong ties and L brackets on the deck frame, and where it was attached to the boat brace, made the brackets shown below. Good luck!</p></blockquote><p></p>
[QUOTE="Earlo, post: 177321, member: 4386"] I second what Josh says. For anything contacting the boat, you can make some brackets out of aluminum angle. Also, be sure and use wood that is NOT pressure treated. The copper in treated wood will contribute to corrosion also. I used galvanized strong ties and L brackets on the deck frame, and where it was attached to the boat brace, made the brackets shown below. Good luck! [/QUOTE]
Boat House
