Boat House
Looking for some opinions
<blockquote data-quote="kfa4303" data-source="post: 251605" data-attributes="member: 7274"><p>HI big wave. Cool boat. Your anti-vent plate is about right. You can actually want it to be level, or up to about 1 1/2" ABOVE the keel (bottom) of the boat. Ideally, it should just barely break the surface of the water when on plane. It may seem a little counter-intuitive, but considering that vessels are stern heavy, the LU will always be well submerged at rest and speed and when you get on plane water is force up the intake to insure proper cooling of the motor while minimizing drag. The more the LU hangs below the keel the more drag you'll experience and the more impaired your performance will be, particularly on the high end. You're set up looks good to go now, but you could probably raise it about an inch and get even better performance on the top end, if that matters to you.</p></blockquote><p></p>
[QUOTE="kfa4303, post: 251605, member: 7274"] HI big wave. Cool boat. Your anti-vent plate is about right. You can actually want it to be level, or up to about 1 1/2" ABOVE the keel (bottom) of the boat. Ideally, it should just barely break the surface of the water when on plane. It may seem a little counter-intuitive, but considering that vessels are stern heavy, the LU will always be well submerged at rest and speed and when you get on plane water is force up the intake to insure proper cooling of the motor while minimizing drag. The more the LU hangs below the keel the more drag you'll experience and the more impaired your performance will be, particularly on the high end. You're set up looks good to go now, but you could probably raise it about an inch and get even better performance on the top end, if that matters to you. [/QUOTE]
Boat House
