Boat House
lowe 1440 jon in pickup truck bed
<blockquote data-quote="bassboy1" data-source="post: 124426" data-attributes="member: 55"><p>Will it fit? No doubt. The only questionable spot is the wheel wells. If the boat slopes too much that it doesn't fit between the wheel wells, block it up. Can't imagine it would need more than 4 inches of blocking. Thus, lay out two 10 - 12 foot 4 x 4s, and not only will they block the boat up, they will further support the suspended section of hull. </p><p></p><p>The worry I have is launching and loading. A 1440 is a pretty good size boat, and you might find loading/unloading that to be quite an issue.</p></blockquote><p></p>
[QUOTE="bassboy1, post: 124426, member: 55"] Will it fit? No doubt. The only questionable spot is the wheel wells. If the boat slopes too much that it doesn't fit between the wheel wells, block it up. Can't imagine it would need more than 4 inches of blocking. Thus, lay out two 10 - 12 foot 4 x 4s, and not only will they block the boat up, they will further support the suspended section of hull. The worry I have is launching and loading. A 1440 is a pretty good size boat, and you might find loading/unloading that to be quite an issue. [/QUOTE]
Boat House
