Boat House
make seat bases more stable??
<blockquote data-quote="Butthead" data-source="post: 184390" data-attributes="member: 637"><p>I would ask the dealer about this. There might not be much you can do until the aluminum cracks. I'm assuming you can't weld aluminum or else you would have cut this out already and shored it up from underneath. <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite8" alt=":D" title="Big grin :D" loading="lazy" data-shortname=":D" /> </p><p></p><p>You could rivet in some 2' aluminum bars or across the mount to keep it from flexing. While this may not look pretty, it would work. The other thing could be to attach a piece of carpeted, weather sealed, 3/4" thick plywood over the affected area with a hole cut out for the seat pedastal to fit through. </p><p>A good size would be 18"x18" with the pedastal hole right in the middle but you could make it whatever size you need.</p></blockquote><p></p>
[QUOTE="Butthead, post: 184390, member: 637"] I would ask the dealer about this. There might not be much you can do until the aluminum cracks. I'm assuming you can't weld aluminum or else you would have cut this out already and shored it up from underneath. :D You could rivet in some 2' aluminum bars or across the mount to keep it from flexing. While this may not look pretty, it would work. The other thing could be to attach a piece of carpeted, weather sealed, 3/4" thick plywood over the affected area with a hole cut out for the seat pedastal to fit through. A good size would be 18"x18" with the pedastal hole right in the middle but you could make it whatever size you need. [/QUOTE]
Boat House
