Motors
Milky oil
<blockquote data-quote="Nohasslekindaguy" data-source="post: 349399" data-attributes="member: 10078"><p>It is listed as a plug/washer assembly. I'm sure you can get the washer separately, but the price listed is reasonable for the assembly. The head of the drain plug is usually chewed up from people using too small of a screwdriver to remove it. This motor uses a plastic washer as a seal. Newer motors have an o ring with a groove machined under the head of the screw.</p></blockquote><p></p>
[QUOTE="Nohasslekindaguy, post: 349399, member: 10078"] It is listed as a plug/washer assembly. I'm sure you can get the washer separately, but the price listed is reasonable for the assembly. The head of the drain plug is usually chewed up from people using too small of a screwdriver to remove it. This motor uses a plastic washer as a seal. Newer motors have an o ring with a groove machined under the head of the screw. [/QUOTE]
Motors
Milky oil
