Motors
Mini Jack plate worth it?
<blockquote data-quote="Alumacraft" data-source="post: 163334" data-attributes="member: 2972"><p>Im 150 lbs I plane out very easily. trolling motor up front, 3 gallon gas tank behind the middle seat. Its pretty fast with just me in the boat.</p><p></p><p>boat 140 lbs</p><p>9.9 evinrude 80 lbs</p><p>me 150 lbs</p><p>TM, battery, gas, gear 80 lbs</p><p></p><p>its only around 450 lbs the 9.9 has to push around. </p><p></p><p>I can go way faster than my bros 12 mirro caft with a 9.9 evinrude :twisted: :twisted: </p><p></p><p>Late winter early spring I'll be putting in a 3/8" floor for the middle and front of the boat and then I'll look for a small jack plate for my boat. I'll probly put the cavitation plate .5" or 1" above the bottom of the boat, but I'll have to play around with it.</p></blockquote><p></p>
[QUOTE="Alumacraft, post: 163334, member: 2972"] Im 150 lbs I plane out very easily. trolling motor up front, 3 gallon gas tank behind the middle seat. Its pretty fast with just me in the boat. boat 140 lbs 9.9 evinrude 80 lbs me 150 lbs TM, battery, gas, gear 80 lbs its only around 450 lbs the 9.9 has to push around. I can go way faster than my bros 12 mirro caft with a 9.9 evinrude :twisted: :twisted: Late winter early spring I'll be putting in a 3/8" floor for the middle and front of the boat and then I'll look for a small jack plate for my boat. I'll probly put the cavitation plate .5" or 1" above the bottom of the boat, but I'll have to play around with it. [/QUOTE]
Motors
