Motors
Mini-jacker ???
<blockquote data-quote="ditchen" data-source="post: 191600" data-attributes="member: 3911"><p>I used "rough baseline", not a standard. It is a useful guideline and I will agree with ya that "All rules do not apply on all boats and engines all the time". I also understand what hulls/outboard combos most are using here and modified v's and flat bottoms are not the same. </p><p></p><p>I wanted to point out that the further that outboard is from the transom, the optimal position will be higher then if it was directly attached to the transom without a jack plate.</p></blockquote><p></p>
[QUOTE="ditchen, post: 191600, member: 3911"] I used "rough baseline", not a standard. It is a useful guideline and I will agree with ya that "All rules do not apply on all boats and engines all the time". I also understand what hulls/outboard combos most are using here and modified v's and flat bottoms are not the same. I wanted to point out that the further that outboard is from the transom, the optimal position will be higher then if it was directly attached to the transom without a jack plate. [/QUOTE]
Motors
Mini-jacker ???
