Motors
Mismatched motor
<blockquote data-quote="Huntingtheworld" data-source="post: 355831" data-attributes="member: 14143"><p>1985 evinrude head 60 hp 1979 55hp frame ect.</p><p>Ok every sense I got the boat it cuts out at half throttle.if I bump the choke it's fine. After it gets past that spot it's good. I've cleaned the carb millions of times ran tiny wire threw the jests still the same thing.when the motor is cold it normally coughs one time.both butterfly's are closed at idle. I was told link and sync well I adjusted the rod yesterday on the water and no difference.i turned it many times with one turn each time. What is going on? :evil:</p></blockquote><p></p>
[QUOTE="Huntingtheworld, post: 355831, member: 14143"] 1985 evinrude head 60 hp 1979 55hp frame ect. Ok every sense I got the boat it cuts out at half throttle.if I bump the choke it's fine. After it gets past that spot it's good. I've cleaned the carb millions of times ran tiny wire threw the jests still the same thing.when the motor is cold it normally coughs one time.both butterfly's are closed at idle. I was told link and sync well I adjusted the rod yesterday on the water and no difference.i turned it many times with one turn each time. What is going on? :evil: [/QUOTE]
Motors
Mismatched motor
