Boat House
Move seat on aluminum boat
<blockquote data-quote="Nevillizer" data-source="post: 167878" data-attributes="member: 1773"><p>Remove the seat. Spilt it right down the center useing a jig saw or other reciprocating saw. Once you have done this you can create wood replacement. Then use the two halves of the original bench as end caps and remount the bench. Attach the ends of the original to the wood and then reinstal. them you can can cover it with some carpet. </p><p></p><p>I have seen this done before and it turned out well and as cheap.</p></blockquote><p></p>
[QUOTE="Nevillizer, post: 167878, member: 1773"] Remove the seat. Spilt it right down the center useing a jig saw or other reciprocating saw. Once you have done this you can create wood replacement. Then use the two halves of the original bench as end caps and remount the bench. Attach the ends of the original to the wood and then reinstal. them you can can cover it with some carpet. I have seen this done before and it turned out well and as cheap. [/QUOTE]
Boat House
