Motors
My jon boat setup tell me what is wrong
<blockquote data-quote="lckstckn2smknbrls" data-source="post: 328538" data-attributes="member: 850"><p>With the 4" of setback your getting from the jack plate I don't think your motor is too high but it might not be at the correct height for your boat motor combo. Drill out a few more of the dimples on the mini jacker and try different heights you my find out your boat needs the motor to be a little lower.</p><p> When I first mounted my mini jacker I set it so the anti-cavitation plate was even with the bottom of the hull. The boat ran good so I tried putting a 1" thick wood block on top of the mini jacker. That was a little better so I raised the mini jacker 1" and tried it again with the 1" wood block and finely end did up with the anti-cavitation 2" above the bottom of the hull.</p></blockquote><p></p>
[QUOTE="lckstckn2smknbrls, post: 328538, member: 850"] With the 4" of setback your getting from the jack plate I don't think your motor is too high but it might not be at the correct height for your boat motor combo. Drill out a few more of the dimples on the mini jacker and try different heights you my find out your boat needs the motor to be a little lower. When I first mounted my mini jacker I set it so the anti-cavitation plate was even with the bottom of the hull. The boat ran good so I tried putting a 1" thick wood block on top of the mini jacker. That was a little better so I raised the mini jacker 1" and tried it again with the 1" wood block and finely end did up with the anti-cavitation 2" above the bottom of the hull. [/QUOTE]
Motors
