Off The Water
Watering Hole
My new boat
<blockquote data-quote="Pont" data-source="post: 36873" data-attributes="member: 204"><p>I'm running a evinrude 60/40 E-tec. Boat is an 18 footer with a 12 gallon tank, 2 Agm batteries, onboard charger, 2 gravity fed livewells under each seat with added aerators. Top speed loaded is about 27 to 30. It just depends if I'm going upstream or down. Going out to the lake I usually burn 3gallons in an 8 hr day. Going to the river, I usually burn about 5 gallons. The jet doctor will customize your boat pretty much to however you want it, so if you want carpet throughout...done. </p><p>Things I would have done different had I had the opportunity..... Extend the front deck further back and gone with a 90 horse e-tec, and ofcourse with a 90 horse jet, up the gas tank to 20 gallon.</p></blockquote><p></p>
[QUOTE="Pont, post: 36873, member: 204"] I'm running a evinrude 60/40 E-tec. Boat is an 18 footer with a 12 gallon tank, 2 Agm batteries, onboard charger, 2 gravity fed livewells under each seat with added aerators. Top speed loaded is about 27 to 30. It just depends if I'm going upstream or down. Going out to the lake I usually burn 3gallons in an 8 hr day. Going to the river, I usually burn about 5 gallons. The jet doctor will customize your boat pretty much to however you want it, so if you want carpet throughout...done. Things I would have done different had I had the opportunity..... Extend the front deck further back and gone with a 90 horse e-tec, and ofcourse with a 90 horse jet, up the gas tank to 20 gallon. [/QUOTE]
Off The Water
Watering Hole
My new boat
