Boat House
Need more rivet help please...
<blockquote data-quote="crazymanme2" data-source="post: 104484" data-attributes="member: 1634"><p>As a general rule the length of your rivet should be 1 1/2 times the dia.So when you stick your rivet through it sticks out 1 1/2 times the dia.If it sticks out a little more that doesn't hurt,but not too much because that isn't good either.The 1 1/2 times is aircraft standard.The rivet you want has a dome & is called a universal rivet,just like the ones in your boat.</p><p> Hope this helps</p></blockquote><p></p>
[QUOTE="crazymanme2, post: 104484, member: 1634"] As a general rule the length of your rivet should be 1 1/2 times the dia.So when you stick your rivet through it sticks out 1 1/2 times the dia.If it sticks out a little more that doesn't hurt,but not too much because that isn't good either.The 1 1/2 times is aircraft standard.The rivet you want has a dome & is called a universal rivet,just like the ones in your boat. Hope this helps [/QUOTE]
Boat House
