Boat House
need some advice
<blockquote data-quote="bassboy1" data-source="post: 37672" data-attributes="member: 55"><p>I don't know. Probably would be about as stable as a 1442, (may be an illusion, but using the motor as a reference, it almost looks like a 36 inch bottom). But, you would have a lot of length to contend with. Seems that if I was living with a 42 inch bottom, I wouldn't go any longer than the 15 I have at the house.</p><p></p><p>Also, take a better look at that motor. It is a jet. Great if you are running shallow rocky rivers, but that is about all they are great for. You lose so much power by putting a jet on it, so you would probably be closer to 25 hp. Plus, they are a bit more complicated to work on.</p></blockquote><p></p>
[QUOTE="bassboy1, post: 37672, member: 55"] I don't know. Probably would be about as stable as a 1442, (may be an illusion, but using the motor as a reference, it almost looks like a 36 inch bottom). But, you would have a lot of length to contend with. Seems that if I was living with a 42 inch bottom, I wouldn't go any longer than the 15 I have at the house. Also, take a better look at that motor. It is a jet. Great if you are running shallow rocky rivers, but that is about all they are great for. You lose so much power by putting a jet on it, so you would probably be closer to 25 hp. Plus, they are a bit more complicated to work on. [/QUOTE]
Boat House
need some advice
